QUOTE(gothspeed @ Jul 10 2012, 12:56 PM)
Hey Gothspeed,
Great Find!
Have you installed this cyl. into a 914? My concern is all the little things like fitting the mounting bolt pattern and having the same spacing so the brake pedal sits in the right position.
If that works, then I'll go this route. The God-awful dual piston Mstr cylinders are only to make Ralph Nader happy, believing that if 1 end of the car failed, the driver would still have 2 wheels left...NONSENSE! If the front brakes fail, we are ALL SCREWED in a 914!
Also, the brake proportioning valve will continue to "assist" in rear wheel lock up as with the original system, even though I hate the spongie pedal.
Since I've driven on-track for decades with no "back-up" system, I'm not going to worry about the silly & complex dual cylinder used in the 914s.
YOU GOT BRAKES, OR YOU DON'T!
Thanks for the great idea!!
Terry
