QUOTE(vintage914racer @ Jul 12 2012, 01:23 PM)
QUOTE(r_towle @ Jul 12 2012, 09:16 AM)
Linkage related most likely...check your bushings and if they are all fine, try adjusting the shift rod at the shifter to slide the shifter onto the shifter rod about another 1/16th or just a hair more...
That little bit may get you into those gears.
Otherwise...do it with 4th...
rich
When you say at the shifter do you mean in the cockpit?
Cockpit, bottom of the shifter handle is a fitting that the shift rod slides into.
Look at if from behind the shifter via the tunnel.
I recall you can do this withou removing the shifter...I adjust it, drive it, adjust it, drive it...till its right.
I believe a 13mm on a long socket extension is what you need.
I also hold the bar with a pair of vise grips from the access panel between the seats at the rear of the cockpit so you have leverage in the car.
Loosen the clamp, slide the rod into the shifter coupling just a smidge (dont rotate it...that will just add more issues) and see if you get 1st and 5th back again....it may just be out of adjustment.
also, check the little coupler underneath the car at the firewall...if that is shot, you will have tons of play in the shifter setup.
The last one is the cup bushing at the shifter console on the transmission...if that blew up (and they do that at times) you will also experience loads of play and may lose parts of the throw of the shifter.
rich
