QUOTE(ape914 @ Jul 14 2012, 11:47 PM)
1...... Cap off the heater hose ports, since you have no exchangers there is no need to cool them with the hoses, or other related tin. cap off the ports to prevent enterance of hot air into the engine bay,
2. you need a thermostat and all flapper parts, would you run a chevy, toyota, or ford with no thermostat installed? get all these important parts installed. Post a wanted ad if you dont have them. I dont know if you can see the flap or not, with the tin installed, but you CAN remove the top tin and gain access WITH OUT removal of the engine. you do have to pull the intake runners off each head, and possibly the distributor and a few other things and then the upper tin can be removed with engine in place.
3.... I assume this is the warm up air snorkle, used on later cars to direct preheaed intake air to the air cleaner when temperature is cold. this aided warm up and reduced cold running pollution You can run without this, without the heat exchanger parts installed, you cant hook up the hot air source anyhow.
1 - leave them open or cap them. You won't notice a difference.
2 - You don't need the thermostat. It's
BETTER if you can run one. But you don't need one in order to safely operate the engine.
3 - It is the warm air port, but it's for early engines (not late) and it gets warm air off the heads, not the heat exchangers. Again, for a stock engine, stock components/setup is best, but you don't need this in place for safe operation of the engine.
