Hey....
thanks for showing....yeah, it is a later Solex carb based on the texture of the body surface (carb body)....the ones I worked on were sand cast type for 4 cammers....however, the ones you have are also used in most 356...some use the Zeniths which I personally think it's piece a crap....
I can maybe see why Jake likes the manifolds....it looks like a beefy one that can withstand any BS going on in the engine compartment
....and what I see and like the most, is the way it holds the crossbar linkage system, independently from the carbs...that's neat if you need to pull the carb fast out without having to mess around with the crossbar....neat...
so Jake, what's got you all "woody" over the manifolds?
i'm curious to know....
