QUOTE(Dave_Darling @ Jul 23 2012, 03:56 PM)
The eyebrow should just be held on by three rubber plugs. You should be able to simply pull it out. Take it to the painter, and it should be enough for them to be able to match.
--DD
i have seen eyebrows held with nuts and bolts, not correct, but if they cat be removed easy, someone might have bolted them on. Not a good idea, they are supposed to be flexible to allow for snow/ ice /debries build-up to not jam up the head lamp movement.
The flexable eyebrow allowed Porsche to design the surrounding headlamp door gap to be nice and narrow when closed, while maintaining the debries clearing ability of a larger, unsightly door gap.
It also makes the headlamp movement less likely a finger breaker to have a flexible eyebrow. But dont try it.
