Here it is in .JPG form:
Click to view attachmentI think I originally mis-read your comment (or you changed what you wrote??)
The description indicates that the limiting valve does act the same as a racing prop valve, with the check valve opening and closing seamlessly as brake pressure increases.
-or now-
Now I understand how it functions as a pressure limiting valve as opposed to the proportioning valves commonly installed in race cars.
I think it's pretty cool that you are digging in to this as it will "HOPEFULLY" change the myth, once and for all in the 914 communities that this is a "Proportioning Valve". I read Alfa forums at times and it's amazing the polarity with the 914 guys on this subject. The important factory manual text is the very last sentence and the words "regulating range". That valve opens and closes when it is in the "regulating range" meaning, once above 525psi this valve does it's thing. Below that... it simply passes fluid like a "T".
I do have major concerns I'll voice though.
1. This is a safety device meant to prevent rear wheel lock in the case of a panic stop. As Chris has now pointed out, it is not like a proportioning valve commonly sold for race applications. Chris, owning your own biz, you may want to add a disclaimer regarding safety and messing with these type components. Renegade still recommends "T's" in their printed literature for 914's and I'm shocked. Any postmortem litigator would have a field day with that. As a respected member here and all-around smart guy, keep in mind a lot of these people will follow you off a cliff, especially if there is some sort of perceived "performance enhancement". 99% of the readers here should NOT TOUCH THIS (that still leaves 77 people I'd be worried about). Dr. Evil, please post pictures of your accident.
2. In "turn it into a true proportioning valve" I would again add that 99% of you have the "opposite" need for such a valve in a 914. As Chris explains...
"After removing the shutoff valve pieces and reassembling the unit, I believe it will act just like the racing prop valves. Ie, at the pressure where the big spring starts moving, the rear brake pressure will begin to increase at a slower rate than the front brake pressure."Allow me to explain:
The MOST DIFFICULT THING TO DO IN A 914 IS TO FIND A LARGER REAR BRAKE SOLUTION. When I say this, I mean a true bolt on solution. The largest you can go and bolt it on is the uber-rare 914-6 rear caliper. That means; no grinding, no welding, no aftermarket cable parts, no 911 bits etc. Those calipers are easily over $1,000 per pair. Compare that to 911 handbrake solutions and various other "money is no object" calipers that can be made to fit... and you are "50:50" on dollars spent. This is more than most have invested in the purchase of their 914 which is why few do it and MANY will be looking for any type of performance enhancement with drool coming out of the corner of their mouth.
The point? The only need for a true proportioning valve in 99% of the vehicles out there would be to "limit" the rear brake pressure. Again
"...the rear brake pressure will begin to increase at a slower rate than the front brake pressure.". The only need for this would be if you bias was now set heavier toward the rear of the car. Quite simply... if you put larger calipers on the back. As mentioned above, that's one of the most difficult things to do on a 914 while still having a ) a handbrake cable and b ) money left in your wallet.
The bias of your brake system was set by the factory engineers. Check the piston sizes on all Porsche vehicles from the 1965 356C on and you will find a fairly constant ratio. None of them have a proportioning valve. Putting a proportioning valve on a 914 can only limit your rear braking ability. This would be the opposite of a brake enhancement for 99% of you. If you're driving a 908 with S-Calipers on all four corners... that valve would come in handy. If you mistakenly put early front 914 calipers on the rear and you don't care about a handbrake... that valve may come in handy.
Most 914 brake "upgrades" have included larger bolt on "front" brake solutions (BMW etc) with no regard for the rear bias. Hence negating the need for a proportioning valve in a 914 (unless you can figure out how to make it work backwards).
Carry on. I'm excited you're digging into this and more excited to see what you come up with.
IMPORTANT - This is a safety device gang. "Please" think 2-3-4-5-600 times before attempting to adjust yours, replace it with a T or modify your brake system at all. This is basically one of the very first "Anti-Lock" brake devices on the market. It will shut your rear caliper off in a panic stop and bring them back into the system as pressure equalizes in that chamber. Think... think... think... Good thing? Bad thing? Good thing? Bad thing?
Stu's pretty close in his reply.
