QUOTE(mrbubblehead @ Jul 28 2012, 06:18 PM)
i dont think any thing from our flaps would be good for our engines. except a diesel engine oil or motor cycle oil (in a pinch). from my research each oil is engineered for a specific purpose. i would rather spend a little more for my oil, and have the peace of mind that i am not harming my engine. these engines are just too damned expensive to rebuild. so im not taking any chances. i have some good reading material on viscosities, engine oil additive packages and so on if you guys are interested in em. real eye openers....
The diesel oils have all been changed as far as I can tell
I know for a fact the rotella and mobil have had all of the zinc taken out.
I can't remember the new diesel certification code (maybe its SJ or CJ ?) anyways all of the diesel oil I have checked has now been changed to no zinc.
Really you have to use the certification
any oil with modern highway certification is bad
we should start a list of the API codes to make this thread useful.
the oils that are good do not have those API codes
I'm using royal purple HPS (their race oil is safe also, but more $ than HPS)
Brad penn should not have an SM certification and is still good last time I checked...
you have to keep tabs on the API certification. that is the only way to know. the cheaper royal purple used to have zinc but its been certified now and no longer does. I got caught out on that one and failed to see the SM certification when I bought 2 cases that I now can not use.(about $110/case). I hadn't bought for a couple of months over the winter and they went and API certified it in the mean time.
The point is... even oils that everyone used to use have been changed.
Look at the certification.
