I got a little time to continue working through my carb and ignition situation today. I won't rehash all of the suggestions that I received, but I wanted to say a particular thanks to Rhodyguy, FourBlades, Racer Chris, The Cabinetmaker, and many many others who helped me! The linkage was one problem, solved with Chris' excellent cable setup, which I highly recommend. Then I moved on to spark and after the extreme rich condition I had with one carb, I had some fouled plugs, fixed with a new set of NGK B5ESs. Also took the chance to replace wires, even though they weren't a culprit. Finally, Kevin loaned me a fuel pressure gauge which helped me determine that I was running at less than 1 psi.
I installed a new rotary-style fuel pump and filter, but still low PSI. I began to fluctuate a little once I let the car sit and fired it up again. That leads me to believe that I have some debris that is clogging up the line at the tank and am still waiting for a new sock for the tank. However, when it is not clogging the line, and PSI is normal, the car runs AMAZING! So very excited. Thank you guys so much, you've made me a really happy dude!
