Some things you will need...
Compressor- You might be able to re-use this. I'm thinking you'll be fine if you do. At the very least you will need some hose adapters.
Condensor- The condensor will go infront of the radiator so as long as the one off the car will fit, go for it. It will need to be flushed before reusing. You will need to wire electric fans to run whenever the A/C is on.
Evaporator(Dash unit)- You can buy a new aftermarket unit or reuse one that came from dealer installed systems. If using a used one, the Expansion valve should be replaced. and the evaporator be flushed.
Reciever Drier-You don't/can't reuse this iten. They are cheap. <$20
Pressure Switch- You'll want to buy a new one. They typically bolt into the drier and are inexpensive.
Hoses- You will need a full set ofcustom hoses made to fit.
Here is one source of aftermarket A/C parts...
http://www.nostalgicairparts.com/
