QUOTE(BarberDave @ Aug 2 2012, 12:55 PM)
Bill: DITTO on the galley plugs ! Cut threads and use pipe plugs ! Dave
Can galleys be tapped without getting metal inside the motor?
When I had mine out, I bought a Victor Reinz rebuild gasket kit and replaced everything that I could get to without pulling the heads. I also put in viton pushrod tube seals, distributor O ring and a front/rear main seals (neither are in the VR kit).
Also:
- new screws for the tin. I think that Mikey sells these or CIP1.com.
- new oil pressure sending unit and grommet (AA was the only place I found it)
- head temp sensor grommet
- bench test your thermostat - you will most likely have to find a good used one. Check with Rich at High Performance House (where I found mine).
- new front, side, rear engine seals - Mikey
- New CV bolts, gaskets
- stainless fuel lines in the tunnel
- disassemble, regrease distributor
- replace soft fuel lines
- oil filter
- check/replace vacuum hoses, manifold hoses
While mine was out, I also pulled the tank and replaced the strainer and all of the soft hoses and filter up front.
I guess I got a little carried away, but now I know what I have, and it doesn't leak a drop.
