metalmorphosis
Aug 2 2012, 09:21 PM
Just wanting to know how to tell if the bellows are good or not? Is there a length it should be at room temp? I assume its fine, it was my dd for years w no problems to speak of. The engine will be going back in the car in a few weeks and its something I don't really want to spend more money on but I want to be right. So what do you guys think?
walterolin
Aug 2 2012, 09:30 PM
Haynes manual, page 13-14 says heat a pan of water to 150-160 degrees F, put your thermostat in the water for a few minutes, and overall length should be 1.81 in (46 mm). An eyeball method is to warm up the water, drop the thermostat in, and see if it expands.
Olin
Spoke
Aug 2 2012, 11:34 PM
Lets see a pic of the thermostat. It is obvious by the room temp position if the thermostat is good.
jimkelly
Aug 3 2012, 05:02 AM
take a peek at this thread - bottom pics in boiling water
http://www.914world.com/bbs2/index.php?act...=0#entry1551011and see this
http://www.914world.com/bbs2/index.php?sho...mba++thermostatshould be compressed at room temp and expand about 1cm hot ??
SUNAB914
Aug 3 2012, 05:46 AM
Can you squeeze it closed? probably bad.
rick 918-S
Aug 3 2012, 07:25 AM
QUOTE(SUNAB914 @ Aug 3 2012, 06:46 AM)
It's assembled in compression, alcohol is added then it's sealed with solder. Heat makes the alcohol expand. So, if its long, it likely either has a slow leak or is cracked and dead.
SUNAB914
Aug 3 2012, 07:51 AM
Yea thats what I said!
reharvey
Aug 3 2012, 09:45 AM
There is a guy on Samba selling new ones for around $100. Why bother with a 40 year old part that will fail.
Dave_Darling
Aug 3 2012, 10:02 AM
Why bother with a 40 year old car that will fail?
--DD
metalmorphosis
Aug 3 2012, 10:05 AM
Thanks to all you guys for the info. I also see there is another thread about this w pics that is helpful. This wkend I'll add some pics and test mine out. Reharvey I think AA has them too for about the same $.
cgnj
Aug 3 2012, 02:16 PM
Here is a link to modify a type 1
type 1 themostat mod
