QUOTE(vw505 @ Aug 2 2012, 10:42 PM)
Every time I press my brake brakes my tach. drops to zero and as does.everything else. Is this being coused buy the peddle witch?
This has been on the forum a few times and there has been a few solutions. Typically its been because of a bad or weak ground. Mine was the left rear taillight bucket connections and the ground point next to the relay board.
I suggest removing your tail lights completely and cleaning all connections then reassemble making sure none of the wires are pinched or spade connectors touching. I had a corroded and broken spade connector touching another where the wires go from the light bucket to the reflectors. Then make your way back to the pedal switch checking connections and cleaning.
Draw a diagram and mark the wires before removing them!
Good luck
