First try to start 2.0 carbs
Tries to start but white-blue smoke from cyl 3 through carb with POP. immediately shut it off before it started.
Valve adjustment gone wrong on that cyl? Carb setting wrong (static setting via Dellorto book) ? Timing not moved since it was a running motor.
What's the order of things to check?
