jim_hoyland
Aug 12 2012, 04:57 PM
Organizing and cleaning the garage and found these two clutch discs; a 4 spring and a 6 spring. Bought the 6 spring disc from GPR at their sale along with a pressure plate.
What's the difference between the two and which one should I keep for my '75 ?
Thestigz06
Aug 12 2012, 05:19 PM
Just my. $.02 but I would keep the 6 spring. It makes the clutch less heavy, or at least in my case, if I'm remembering right 914's came stock with 4 spring clutches.
reharvey
Aug 12 2012, 05:28 PM
QUOTE(Thestigz06 @ Aug 12 2012, 07:19 PM)
Yes---use the 6 spring disc
Andyrew
Aug 12 2012, 05:33 PM
6 spring looks like every other clutch that I've ever installed.
Drums66
Aug 12 2012, 05:43 PM
...I put a 6-spring in my car 75'w Ljet.......I've driven with both
6 action was better!! I won't go back.(enhancement for sure)
toolguy
Aug 12 2012, 07:13 PM
IIRC. . . the 6 spring disc is a 911. . also used in 914-6, interchanges with the stock 914 4 spring disc.
SLITS
Aug 12 2012, 09:45 PM
The early /4s used a 4 spring clutch disc. The 2.0L used the 6 spring along with the 914/6.
The difference .... supposedly the take up (clutch engagement) is smoother with the six spring. That's it.
I believe all clutch replacement packages are 6 spring now.
