With the trans cooler:
I'm getting 220 degree's after 20 minute vintage race with a 2liter on an 80 degree day at coronado island/sea level
(I also ran at hallet, oklahoma which is 900ft above sea level. I still ran 220 on an 80degree ambient day)
imagine what I was getting before the cooler at the event I blew the trans up last july. It was a 110 degree day and we had 2 drivers on the car that day, running back to back sessions at 5000ft of elevation where the air is less dense and cooling less efficient by far...
I didn't have a gauge on it then, but I'm guessing 260f or more is the norm without a cooler (in a 20 minute session with a tiny 2.0 motor)
I also would theorize that lower gears, smaller diameter wheels, more rpm and definitely a clutch limited slip differential would add to the heat problem if a person has any of those contributing factors.
putting a gauge on the tranny is a real eye opener... no wonder everyone has always said the 901 couldn't handle high hp. I still believe its a 250hp tranny but that keeping oil temps in check is mandatory just like you would for a motor.
for example, you don't hear people recommending to skip front coolers on race cars or that its a waste of time to install an oil temp gauge for an air cooled motor.
brant
QUOTE(naro914 @ Nov 9 2012, 03:19 AM)
QUOTE(larryM @ Nov 8 2012, 11:35 PM)
but - WHY ??
it makes sense for a 24-hrs enduro World Makes Championship run in 1970-72
but vintage racing today is only about 15-20 minutes on track
so why bother -??
(yep - i know - i BTDT - old age now questions the folly of my youthful fevers)
Are you asking "why bother with trans cooling"?
Agreed, if you're running stock engine, wheels, etc. probably no need.
But I'm pushing 330 +/- hp with the stress of 12" wide slicks through a basically stock 901 trans that was build with about 100 hp in mind back in the day... THAT'S why.
Plus, PCA enduro races are 90 minutes.
