QUOTE(cgnj @ Aug 16 2012, 04:43 PM)
Hi,
Out of the box, the flowed better the webers because they shipped with bigger vents from CB Performance.
Why dells are better? Right and left handed castings, check the pns you will see they are different, so the throttle return springs are on the same side as the linkage on each carb. 5 progression ports mean better off idle response (Don't recall how many on the webber, just know it is less). Banjo (fuel splitter) can be moved from either carb.
Good score, I dont recall the vent size shipped on the 36's, I know it's bigger than 28.
Carlos
Thanks, Carlos.
I really was open to Webers or Dellortos. These came my way and I read up on them on 914 to see which way to go. The Dell's seemed to have some good press so I jumped on the deal. I think I did all right....four Dell 36's (two rebuilt a year ago), four manifolds, linkages, and 1 hex bar
