MikeM
Aug 14 2012, 01:32 PM
Hi all...
When you guys replace pushrod tube seals, do you usually drop the motor or do it with the motor in the car?
Wondering if there is room...stock 2.0 liter with heat exchangers...
Thanks,
Mike
ThePaintedMan
Aug 14 2012, 02:25 PM
Oooh... a 2.0, I wouldn't know for sure. But on my 1.7, it was pretty easy to do with the engine in the car. Didn't even need to loosen the engine mounts. On some of the tubes, you will need to remove the pushrod first, or remove the tube part way, then remove the pushrod to gain enough clearance to get the tube out all the way. It helped me immensely to clean the engine well first to keep the amount of grit down and out of the sealing area.
URY914
Aug 14 2012, 02:39 PM
Getting things clean and keep it clean throughout the seal change out process is very important. You don't need (and can't) remove the tube completely from the engine but you can still change the seals.
ThePaintedMan
Aug 14 2012, 02:55 PM
QUOTE(URY914 @ Aug 14 2012, 04:39 PM)
Paul, is that for 2.0s or all engines? I was able to remove all of my tubes completely. Like I said, I needed to fanagle them, but I did get them all the way out. Again, not completely necessary but it allowed me to get them really clean before reinstallation.
Dave_Darling
Aug 14 2012, 08:55 PM
In the car, for any of the four-cylinder motors. It may be tougher with the 75-76 heat exchangers, but I think it's still doable. You can maneuver the tubes all the way out, but you don't have to. You can leave the tube hanging by its middle through the head, and replace the seals.
--DD
