Couple of years ago I checked out a modified 1.8 ( now for sale in the classifieds) that had just installed the Tangerine exhaust. This car had some added pep; the owner sent me the following email explaining the mods he did. I did drive the car and can verify the changes made a difference:
" Here is the link the owner referenced, and his modifications ( in quotes) :
http://www.opeltuners.com, then select articles Engine Tuning injection specs; About Opel FI system
"The 1975 914 uses the L Jetronic system. It is the best of all the injection systems used in the 70’s and 80’s. You will find the L system on Opals, Range Rovers, Porsche 911’s, BMW and others. You may also use parts off these cars if the pins are the same for the airbox. You can also use the throttle body off these cars if the pins are the same.
In the articles from opeltuners, you will notice that a small change in throttle body and airbox means a large change in available horsepower. The throttle body that is on the 1.8 is good for 160 hp. Just clean up the rough edges inside the throttle and airbox with a grinder and you will be set. Next step is to increase the fuel flow to the engine. You can do this by larger fuel rails, and lowering the full on timing of the injectors to 3000 RPM. Down from the normal 3500 – 3800 stock setting.
I replaced the injectors with stock Bosch; increased the fuel pressure to 43 #; lowered the full on timing of the injectors to 3000RPM. Then I reduced the spring tension in the airbox by a -4clicks and increased the injectors on-time in the lower RPM by one contact slot on the inside dial of the airbox ( inside the tension spring adjuster ) This inside adjuster set the idle to 1000RPM, but made the idle rich so I leaned the low RPM using the bleed screw on the top of the air box. This lets the air by pass the airbox and go directly into the intake after the throttle body, leaning the mixture at low RPM.
So, I have increased the airflow through the engine by exhaust and small mods to the sir box; increased the fuel flow at low and high RPM; and leaned the mixture at idle."
