Hello again, I'm back to pester you all with more questions.
After my exhaust debacle, I'm still trying to figure out why I'm losing fuel pressure over time. First of all, the car is a '73 converted to dual Webers with rotary fuel pump mounted just below the battery. Initially I had installed the tank without a strainer, which I recently replaced. While out, I cleaned the tank well, and inspected all lines - no blockages. The line at the tank is not kinked either and the fuel filter before the pump is brand new. The pump is definitely working and getting voltage and its brand new. Kevin (rhodyguy) allowed me to borrow a fuel pressure gauge for the time being and I have verified that I get exactly 3.5 PSI at first startup and idle. Then, with a couple drives around the block, the PSI drops to almost zero, the clear fuel filer after the pump is almost dry and the car stumbles on acceleration. The tank is vented properly with a vaccuumline that runs out under the drivers side of the car.
When I first got the car it had a Facet style pump, but it was mounted very low on the firewall, almost parallel with the line. Maybe moving it higher like this and combined with being a "pull" rather than a "push" setup is causing the pump to starve?
