QUOTE(kg6dxn @ Aug 18 2012, 06:45 AM)
Before you troubleshoot anything, do this...
Disconnect battery
remove fuse panel under dash
find ground stud
remove nut and clean all terminals with wire wheel or emery cloth
replace all grounds, nut and tighten
replace fuse panel
reconnect battery
Now what is your car doing? Same thing? if so check all the ground connections behind the gauge cluster. test again...
Sorry mike, this was moved after I reposted. I'll get that fuse box out and follow your instructions. I figured it might be a ground...years ago I owned British cars and the solution in most cases was the same
Cheers
