I'm in the process of rebuilding 1.7 type 4 engine for a 912 swap. i purchased it assuming it was a 1.7. I'm going to replace the pistons and cylinders because I'm not sure of compression in this engine. I measured the original pistons and they are 92.88 mm dia. witch would make it a 1.8. my question is,
(1) are the 1.7 piston 90 or 93 mm in dia?
(2) if i have a 1.7 can i put larger piston/cylinders in?
(3) if i can go larger how big can i go?
(3)are the blocks, cranks, rods and heads all the same for 2.0
