rettigdw914
Aug 18 2012, 03:28 PM
I am cleaning out the garage and selling my 914 parts.
Here they are:
Parts all 1973 914 unless otherwise specified Cost
PIC 1
Porsche Haynes Manual $10.00
How to rebuild you Volkswagon $10.00
Porsche Factory Service manual (CDROM electronically searchable) $20.00
[s]Pedal assembly with brake switch $10.00 SOLD
PIC 2
1972 ECU (works) $50.00
Cluster (not sure if it works) $10.00 SOLD
1972 Fuel injection wire harness off of a working car $10.00
PIC 3
Porsche Bra $20.00 SOLD
PIC 4, 5
Used side shift tranny (PO said it worked OK. I used the 1st gear dog teeth to repair my car. it is missing a drain plug , the 1st gear synchro and dog teeth. Also the rear cover has a crached piece about 2" long which could be repaired. Good parts tranny for remaining gears. $100.00
PIC 6
Leather center console - Black $10.00 SOLD
Used Koni's with springs- I confirmed with the factory they fit the 1973 914 $30.00 [b]SOLD
Bilstein jack $25.00
Door Handle covers, targa holder clip from trunk, and shift linkage bushings $15.00
PIC7
1972 oil bath air filter housing $10.00
Valve cover gaskets $10.00
air filter housing bracket with 2 wingnuts $10.00
winshield washer tank $10.00
working throttle body (off of running car) $20.00
intake plenum with cold start and temp sensor (off of running car) $70.00
Auxillary air regulator (works) $40.00
Bosch Fuel Pressure regulator (unknown) $10.00
Fuel line manifolds (2) $5.00
Bosch Fuel Pump (spins with 12v connected) $40.00
new distributor condenser $5.00
intake manifold left and right $20.00
fuel tank rubber mounts $10.00
Buy all the parts together for $450.00 plus shipping and I will throw in the parts in PIC8
PIC8
Spark plug wires - worked OK on car
"Spare - partially working parts:
ECU - broken does not work
brake caliper - frozen
fog lamp - bulb out
2 - MPS - for parts only
4 - injectors - 2 click on and off, the others frozen[/s]
Thanks
Don
billh1963
Aug 18 2012, 03:36 PM
I'll take the pedal assembly, gauge cluster, and arm rest(center console), and koni's with springs
rettigdw914
Aug 18 2012, 06:37 PM
QUOTE(billh1963 @ Aug 18 2012, 01:36 PM)
OK, you got them. I'll send you a PM.
Steve Snyder
Aug 18 2012, 06:55 PM
I'll take the bra and the tow eye. PM sent. Thanks!
rettigdw914
Aug 19 2012, 08:15 AM
Also , feel free to make offers.
rettigdw914
Aug 19 2012, 10:13 AM
tow hook and basket weave material are sold as well.
rettigdw914
Sep 23 2016, 05:48 PM
Hello, Resurrecting an old classified ad here. The remaining parts from the list at the top of the thread were boxed up and stored for a few years and now they must go. Local pickup only, feel free to stop by Greenwood or I can meet in the indianapolis area and we can settle on a price.
e-mail: dwrettig@sbcglobal.net or text at 317-460-7049
Thanks.
Don
yello914
Sep 23 2016, 05:54 PM
QUOTE(rettigdw914 @ Sep 23 2016, 04:48 PM)
Thanks.
Don
I'll take the Bilstein jack
housepumpinpc
Sep 23 2016, 08:34 PM
Sent you a txt.
rettigdw914
Sep 26 2016, 02:08 PM
Attn: All parts are sold. Thank You.
