QUOTE(Cap'n Krusty @ Aug 20 2012, 01:01 PM)
10 w 30 DOES NOT work just as well as 20 w 50! At its thickest it's barely thicker than the thinnest 20 w 50 gets.
The Cap'n
What does that mean John?
If 10w30 didn't work well, the oil mfrs wouldn't bother making it.
The only issue of importance (outside of detergent and anti-wear additives) is that the oil protects the bearings from contacting the journals.
The range of seasonal temps for a particular vehicle is an important factor when deciding which oil to use.
As long as the oil reaches
all the bearings and provides a layer of protection any extra viscosity wastes horsepower by loading up the oil pump.
In addition, oil which is too heavy may not reach all the bearings effectively.
Oil wt numbers represent viscosity at two temperatures.
The first number is for cold oil, the second is for hot oil.
I don't recall the specific temps but all oils are measured to the same standard.
However, the manner in which the oil is formulated to meet a specific standard varies with the type of base stock used, and how a particular oil behaves at temps outside the standard may vary widely.
There are 5 motor oil base stock groups, Group I and II are petroleum based (dino), III, IV and V are synthetic. Its almost impossible to know what a particular oil company uses for base stock unless they fully disclose their formulation or you read deeply into the data.
Regardless of the base stock and additive package, the numbers tell the most important story.
10w "winter" weight is plenty thick for cold operation in almost all engines in the continental US. In fact 20w is often too thick unless bearing clearances are intentionally high from race prep or worn from age.
30 hot weight is fine for engines with moderate bearing clearance up to reasonable oil temps.
Higher weight oils are only useful with high bearing clearances or high temps.
The only way to know which oil is best for
your engine is to monitor oil pressure and temperature.
When I was using BP 20/50, the pressures were too high on startup, even in 75 degree temps. That's why I switched to 10/30.
My experience suggests the 30 hot weight isn't quite sufficient because occasionally my oil temps exceed 220F where the pressures go a little below my expection of 10psi/1000rpm.
Rather than changing oil viscosity with the seasons, more than likely, I'm going to settle on 10w40 for year round use.
The temp range I operate in is 20F to 100F air temps.
YMMV
