I was able to work on the 914 for the first time today. I decided I needed a base line for some of the more important parts to I replaced everything on the ignition side. (cap, rotor, points, condenser, coil, plugs) It seems to be running better, but on a highway cruise one of the spark plug wires popped off. I pulled over, put it back on and all is good, but they don't seem to have very good hold of the plug. They are a set of Bosch wires recently replaced, so I wasn't going to replace them. But with this proving an issue already I was wondering if there was a better option out there.
Other questions. I got a set of points to put in but it looks like it's been converted to electronic ignition. Is that a pretty reliable system? It's not stock is it?
The old plugs were gaped much tighter (0.024 vs 0.028) and I wanted to see if I had it right at 0.028. Seems to run better, bet that might possibly be because they are torqued down instead of hand tight like the others seemed to have been.
Also, where is the temperature sensor on the engine? I'm not showing any reading and wanted to be sure it was at least hooked up.
Lastly, there is a fuel junction under the air cleaner towards the front. It has an electrical connection and two fuel lines. One runs to each set of injectors. What is it's purpose? It was leaking when I picked the car up and I unplugged it and it seems to have been fine sense but I'm assuming I want that to work eventually.
I'll stop there for now, I don't want to wear out my welcome. I need to get back to pulling the tranny out of the Audi. Play time with the 914 is over.
