Pesky 914
Oct 24 2004, 08:13 PM
Can someone tell me if this is a 911 rear hub or a drilled 914/4 hub (I think it's a 911 hub sinec I only see one hole...).
Also, what are a pair of 914/6 stub axles w/911 rear hubs worth?
Pesky 914
Oct 24 2004, 08:16 PM
the hub
736conver
Oct 24 2004, 08:17 PM
They dont look like redrilled 4. They are most likey 911, 914-6
Pesky 914
Oct 24 2004, 08:25 PM
QUOTE(736conver @ Oct 24 2004, 06:17 PM)
Isn't the difference between 914/4 and 914/6 stub axles the number of splines? How many does each one have? (I figure I can count mine just to make sure)
Aaron Cox
Oct 24 2004, 08:27 PM
those look like 911 or 914/6 hubs (are they the same???
) the two holes on the hub are threaded for the rotor to be held down by a screw or 2
Pesky 914
Oct 24 2004, 08:35 PM
Are these hubs & half shafts (w/ the 914/6 stub axles) worth anything? (yes, I'm parting out my car after a little, er, "incident" at Lime Rock in Sept...)
J P Stein
Oct 24 2004, 09:05 PM
QUOTE(Pesky 914 @ Oct 24 2004, 06:35 PM)
Yes indeedie. Prolly worth somewhere around $400-600...or what ever you can get on evilbay
Parting a race car.....whut else ya gots?
nickg
Oct 24 2004, 09:36 PM
wow, i listed mine for 300 and had like 5 guys saying i was crazy high....go figure. and 911 and 914-6 hubs are the same if you use early 911 rear hubs
J P Stein
Oct 24 2004, 10:20 PM
Hubs & stub axles together would prolly be worth that much.
type47fan
Oct 24 2004, 10:40 PM
Should be a P/N cast into the backside of the hub: 901 331 065 XX (the -6 didn't have the three hub centric lugs{?})
Wayne (type47fan)
Pesky 914
Oct 27 2004, 05:58 AM
QUOTE(J P Stein @ Oct 24 2004, 07:05 PM)
I'll post something in the race classifieds with what I have.
davep
Oct 27 2004, 09:43 AM
Definitely 911 rear hubs. The extra big hole there is for the parking brake adjust. Don't know if the 914/6 had it or not. Someone please verify. As a set, the hubs and stub axles are certainly worth good money. Even better is the trailing arms and axles complete.
