So, after many years and way too many dollars I got to drive it. Other than a quick blat around the block to make sure it was worth taking to the track, it hasn't been driven since '99.
With much anticipation we set out for Wakefield Park a small circuit 200 kms south of Sydney for an open track/test day. Wasted no time unloading the trailer and made the first street group run of the day.
After getting it warmed up on the first couple of laps I gave it some stick and while fun I came in feeling underwhelmed by the performance. On the main straight I had to wring it's neck in 3rd before a quick change into 4th and then back to 3rd for turn #1.
Through the technical section the car handled and braked really well and felt solid. The problem: the engine is a worn 2.4/6 pushing through an adapted 915. The ratios are all wrong. I didn't factor that in with conversion and it just doesn't cut it.
There is only one solution...time for a 3.2 Euro Spec Had a great day just the same and ended up getting about 50 or so laps in.
Some pix at the track follow.
