$75 shipped for both.
Both are still in the unopened boxes from POR. I bought the fuel tank kit 2 weeks ago and the starter kit a couple of months ago, so neither has been sitting long.
Super Starter Kit:
here is the description from POR:
http://www.por15.com/SUPER-STARTER-KIT/productinfo/SSKB/
We created the SUPER STARTER KIT in response to requests from customers anxious to try out the entire 3-step rust-stopping system, as well as those customers who need to cut oily residue on the metal they plan to paint.
You'll get a 4 oz. can of POR-15® (enough to cover 6 square feet with 2 coats), a half-pint of PREP & READY™, two wooden handle paint brushes, and a pair of our special high-dexterity surgical latex gloves, PLUS an 8-ounce bottle of our famous MARINE CLEAN™, the world's greatest WATER BASED degreaser
Fuel Tank Repair Kit
here is the description for this one from POR:
http://www.por15.com/FUEL-TANK-REPAIR-KIT/productinfo/FTRK/
FUEL TANK REPAIR is more than just pouring in a quart of sealer and sloshing it around. If gum, varnish, sludge, or fuel are inside, they must be removed first.
Our U.S. STANDARD TANK SEALER™, like all other sealers, will not work in a contaminated tank. Find out what the pros already know... our FUEL TANK REPAIR KIT has everything you need to do the job right!
Kit Contains:
MARINE CLEAN™ to remove gum, sludge, varnish
PREP & READY™ to remove rust & prepare tank for sealer
U.S. STANDARD TANK SEALER™ to permanently seal tank
FUEL PRESERVATIVE & STABILIZER™ to keep the fuel system trouble-free
DETAILED INSTRUCTIONS so you'll do the job right.
Kit Contains:
