IronHillRestorations
Aug 28 2012, 01:53 PM
I've got a car coming my way for a short list of small minor issues to fix. One of the problems is the wipers won't park properly. It's been over ten years since I've addressed this problem and I can't remember the fix.
Valy
Aug 28 2012, 02:07 PM
replace wiper switch
tomeric914
Aug 28 2012, 07:29 PM
Check to see if it has intermittent wipers. Replace the relay if it's missing. Then make sure the ground is in place.
ThinAir
Aug 28 2012, 10:58 PM
Mine won't park unless I shut them off within just the right range from the bottom of the stroke. I don't have intermittent wipers (although I'd like to). Is it really certain that this kind of thing is the wiper switch? That's easier than a problem with the wiper motor.
ThinAir
Aug 30 2012, 10:30 PM
daniel951
Oct 30 2012, 12:10 PM
make sure there is power on the park circuit of the motor.
could be an issue with the park points in the motor as well. hope that helps
76-914
Oct 30 2012, 03:02 PM
mine happened when one pin in the intermittent relay slipped and wasn't making contact. IIRC, it was the grnd from turn signal assm. Possibly white w/ brn strip???
