I have the center console, i removed the clock. I put a oil pressure gauge in the hole, ran the wire to the dual sender. I want to jump the power and ground from one of the other 2 gauges. I figure between oil temp or volt ; go with the volt gauge. It is already switched, but then i was thinking how this voltmeter is affected by the brake lights, turn signals etc.
Is this a bad idea?
Why run more wires to the fuse box if you dont have to??
