kbrunk1
Aug 30 2012, 08:28 PM
Do you have to use the $12 each Fuel Injector Line Elbow's
What happens if you just use fuel line?
Are folks buying 8mm fuel line?
Where?
Thanks
Mike Bellis
Aug 30 2012, 08:32 PM
If the line kinks from bending, it will effect the fuel flow... That's why they have elbows.
cary
Aug 30 2012, 08:56 PM
You can use fuel line. But you'll need to leave them longer so they don't kink.
My .02c.
914Sixer
Aug 30 2012, 08:58 PM
It is bent for a reason.
walterolin
Aug 30 2012, 09:53 PM
FWIW I've run fuel line on a 1.7 for 35 years. I change the lines about every for years, and as Cary said above, I leave them a little long so they won't kink. You have to pull them back when you drop the engine.
Olin
IronHillRestorations
Aug 30 2012, 10:16 PM
If you consider they'll probably last at least 10 years, why not get the real deal?
tod914
Aug 30 2012, 10:37 PM
7mm ID or 5/16ths line work well. I though you could also go super short on them, so there is only a fraction amount of hose between the injector and rail. Might be worth testing. It will drop the rails down abit lower. With the longer lines, I didn't like the way it was butted up under the MPS. Alot of guys are using the R009 rated fuel line now to combat the ethenol gas.
BMW also has rubber elbows that are much cheaper than the OEM ones. They are probally 8mm ID. Should be a thread somewhere on it.
pilothyer
Aug 31 2012, 12:23 AM
Another "point to ponder" is, Can you get the new elbows in the newer "Flex Fuel" grade for Ethanol mix fuel ??????? If not you may have to skip the preformed elbows.
Bartlett 914
Aug 31 2012, 07:29 AM
QUOTE(pilothyer @ Aug 31 2012, 01:23 AM)
Good point
Biggest problem I see is in dropping the engine. Without the elbows, they will get hung up in the engine shelf. You have to be extra careful when dropping the engine.
sean_v8_914
Aug 31 2012, 07:53 AM
mps side can not be long
TheCabinetmaker
Aug 31 2012, 08:36 AM
I cut a short length of hose, zip tie tight thru the hose and around a 1 1/2" dowel or pipe, and use a heat gun to soften it slightly. When it cools, the bend stays.
I don't cook it, just warm enough to make it unpleasant it to touch.
pete000
Aug 31 2012, 11:48 PM
I popped for the OE bent ones. Not cheap but heck it gasoline going through there in a hot engine room.
