For Sale: 1972 Porsche 914 v8. There are a lot of 914s around with v8 engines, but none like this. This car was built for the owner of Renegade Hybrids and has every major upgrade you could want.
This car weighs about 2500lbs. It has around 450hp. Redline is 7,000RPM. Electronic Fuel Injection is already tuned but is programmable with included module.
Body
-Clean title rust-free 1972 Porsche 914 chassis
-Registered in California. 1972 Does not require smog check
-Eight point rollcage tied to front and rear suspension mounts
-Steel slant nose fenders
Engine
-4-bolt Main Chevrolet 350cid block
-Edelbrock Performer RPM in-port programmable electronic fuel injection
-Mallory electronic distributor controlled by EFI computer
-Edelbrock Performer RPM aluminum heads
-Edelbrock Performer RPM camshaft
-4-into-1 stainless ceramic coated headers
-Borla XR-1 stainless ceramic coated race mufflers
-Renegade Hybrids front mounted radiator with thermally controlled electric fans
Transmission
-Porsche 930 4-speed transaxle, has case machined for R&P flip
-Limited Slip Differential
-Porsche 930 CV joints and axles
-Porsche 930 clutch with custom control cable
-Custom Cable shifter. Precise short throw. This is the best shifting 914 you will ever drive.
Interior
-Custom made orange-on-black gauges by Hollywood Speedometer. These are the best!
-All new interior panels and carpets.
-5-point RJS camlock seatbelts
Suspension
-True 5-lug conversion using 930 hubs and flanges
-Porsche Boxster 17x8 alloy wheels
-Porsche 930 Bilstein front end
-Porsche 930 front swaybar
-SSBC Renegade ventilated brakes
-Bilstein rear coilovers
-Boxed rear trailing arms for added strength
-Solid suspension bushings
-225/45R17 Falken Azenis RT-615 tires
Call Larry 408-656-0557
Please click on the images for a larger view
