Full Version: Quick question - best way to remove headlight switch?
KaptKaos
I have the bottom half of the dash off, and the knob and bezel off of the hedlight switch. What's the easiest way to get access to it to remove/replace?
Let me know.
.ps I am thinking either take off the gauge panel or drop the fuse box. Thoughts?
KaptKaos
Got the switch out, but now have a different question.
I have an older 10-pin switch. My replacement, which I am not sure is good, is 11-pin.
1) How do I test the 11-pin with a multi-meter to see if it is good?
B) If it is good, how do I use the 11-pin with the 10=pin wiring?
For now, I put the 10-pin back, albeit cleaned up a little. Maybe it will work better now, we'll see.
tod914
x
