QUOTE(minnesota loon @ Sep 4 2012, 07:38 AM)
I used a grease gun hose it worked for a while but got clogged. Just last weekend I installed a 5" strait piece of pipe comes just above the distributor attached the sender it works well. The pipe has a much better oil flow. Male/female brass connector to engine,5" pipe,female/female connector,sensor.I am at work I will try to send picture later
I had a friend use a straight pipe and it eventually cracked and oil spewed out. I think the vibration in conjunction with the weight of the sender on top of the pipe is what caused it to crack. Keep an eye on yours. His did last for years before the failure.
I have the VDO hose/mount kit and it seems to work well, however I do get an occasional low reading and am wondering if it's trapped air.
