stuttgart46
Sep 6 2012, 07:56 AM
Getting close to installing my AA Steel Flares and I was wondering what you guys have installed for wheels and tires underneath them.
I would love to see some pics and specs if you're willing to share.
Thanks,
Chad
bulitt
Sep 6 2012, 08:07 AM
Quite a few threads on this. Use the search button.
Here is one for you to look at-
wheel thread
jfort
Sep 6 2012, 01:26 PM
front wheels: 7x16, tires Hankook 225/45
74mm studs, 21mm 944 spacer
rear wheels 8x16, tires Hankook 245/45
tomeric914
Sep 6 2012, 09:52 PM
225/55R16 front on 7x16 Fuchs with 8mm spacers
245/50R16 back on 8x16 Fuchs with no spacers
Fuchs are 911 offset
http://www.914world.com/bbs2/index.php?s=&...t&p=1478018
ConeDodger
Sep 6 2012, 10:35 PM
It looks to me like you could put 8X16 up front. I put 7X16 up front and I have lots of room. Harvey Weidman has offered to widen my front wheels and I believe that Harvey knows EXACTLY what will fit. My rear wheels are custom made 8.5X16 wheels and while they would have been perfect on a set of factory flares, the AA flares required some Original Customs magic to make them work as the AA flares have more of a flange on them.
I'm on my iPad now but I will post a picture of mine with the custom Weidman RSR finish wheels when I get a chance to edit...
stuttgart46
Sep 7 2012, 06:51 AM
Thanks guys.
I ran a square set up on my old race car, all 4 8x15's. They were FG flares though. I was curious to see if anybody had done this with the AA steel flares.
GeorgeRud
Sep 7 2012, 07:02 AM
The AA flares are nicely made, and they do deserve kudos for making these available.
With any installation of flares, be sure to have the wheel/tire combination that you intend to use on the car when the flares are being fitted as good body men can tweak things to fit. It's a bit of skill and a bit of magic to see how these body magicians can make things fit beautifully!
ConeDodger
Sep 7 2012, 09:58 AM
There, I added pictures. In the middle one, at 10 O'clock on the rear wheel, you can see where McMark modified the AA flare to accommodate the 8.5X16 rear wheel. Mark speculated that if this had been a factory flare it would have fit like a glove because the factory flare doesn't have quite the flange the AA flares have.
Now look at the bottom left picture, this is a 7X16 911 offset wheel. I am using the stock 4 lug front suspension, albeit with many modifications to make it handle but the point is that there seems to be room for an 8X16 wheel.
gothspeed
Sep 7 2012, 04:45 PM
QUOTE(ConeDodger @ Sep 7 2012, 08:58 AM)
I always like looking at those pics of your flared teener ......... that trim mod on the inside lip, looks just as it is done on the factory non-flared cars
............. was this mod done only to the rear or also the front?
tomeric914
Sep 7 2012, 05:13 PM
QUOTE(gothspeed @ Sep 7 2012, 06:45 PM)
I always like looking at those pics of your flared teener ......... that trim mod on the inside lip, looks just it is done on the factory non-flared cars
Here's mine
For factory non-flared cars, it was only done to the rear. The front is rolled.
I'm in the same camp with ConeDodger in that I don't think a wider tire or wider spacers would fit up front without rubbing. Once in a while, if I crank the wheel while backing up, the front tire will grab the fat fender lip and pull it down.
gothspeed
Sep 9 2012, 06:49 PM
QUOTE(tomeric914 @ Sep 7 2012, 04:13 PM)
Here's mine .............................................
Great info Tomeric
! ......... looks like I will be trimming both front and rear flares ........ I tried rolling one of them but the metal was too thick .... it would not go down without affecting the shape of the flare ............. thanks again for the picture!!
Trekkor
Sep 9 2012, 08:14 PM
I run 8's and 10's under my FG flares.
KT
benalishhero
Sep 12 2012, 03:59 PM
Speaking of flares. I ran into someone the other day from Germany who claims he owned a 1974 2.0 with rear flares from the factory. Did these exist? He said he imported it to the states, which he sold back in the early nineties. Did any non GT cars come with flares?
ConeDodger
Sep 12 2012, 05:51 PM
QUOTE(benalishhero @ Sep 12 2012, 01:59 PM)
Well, you could special order colors... But, I doubt it. More likely installed by a dealership or independent body shop...
RON S.
Sep 12 2012, 06:24 PM
Mine are AA flares I put on back in 2007 during the 1st group buy.
On mine I widened the rears 2'' per side to allow me to run 18x10's on the back.
5 years on now, no problems at all...
The AA flares are a really good reproduction. Hat's off to George
for sticking it out so long to get the product right. He hit the bullseye on that one.
Ron
gothspeed
Sep 12 2012, 10:04 PM
looks freakin great!!! ......... is that wideneing service expensive? I like how your wheels look like the 8x15 but are 16s ..
what tire profile/sizes are you running front and rear?
RON S.
Sep 13 2012, 01:46 PM
looks freakin great!!! ......... is that wideneing service expensive? I like how your look like the 8x15 but are 16s ..
You can pay someone to do the widening, but I did it myself...
I paid me...
Ron
