Well I juiced up the fuel system for the first time, love the smell of race gas in the evening. Put about 5 gallons of VP 110 in the cel.
First ran the pump with each carb feed separate to purge the lines of debris and old fuel, then hooked them up and powered up the pump. Pressure is right at 3psi from the start. Was worried it would be higher but it is perfect and I think I can tune it to go lower if I have to.
Next step is prime the oil system and see if she fires. How will I sleep tonight?
