QUOTE(cal914 @ Sep 8 2012, 04:04 PM)
to rebuild is that expensive would a VW transmission work or are they totally different
As others have said, start with something cheap, like all of the bushings. To answer you question though, no a VW trans won't work, or not without some serious engineering. VWs are rear engine, our cars are mid. Therefore, you would not only have 4 gears, but 4 gears in the wrong direction. Again, start with bushings, probably a trans oil change as well. After that, you would then start worrying about rebuilding it.
