00r101
Sep 16 2012, 11:30 AM
So I picked up a '74 914 1.8 for track days this spring. Good cage, gutted interior, Momo fiberglass shells, fiberglass front and rear hoods. Engine is stock other than a single 2bbl downdraft. Koni singles, bars and springs. Larger brakes front and rear. Stock exhaust manifolds into stainless heat exchangers and then single straight pipe.
Two track events this year, Summit Point Shenendoah and The Glen. Had a great time. car is well sorted handling wise but needs more power (don't we all :-)
I have all fall and winter and would like 20+ more HP. Budget is limited but I want to build for the future so would like a phased approach. I am very interested in hearing your recommendations and experiences with various aftermarket carb setups, ignition setups, and exhaust. DO not have the funding this year to open up the engine so keep your ideas to bolton performance.
TIA,
Alan
mrbubblehead
Sep 16 2012, 08:34 PM
dual carbs will make a big difference.
patrick3000
Sep 21 2012, 07:58 PM
QUOTE(mrbubblehead @ Sep 16 2012, 10:34 PM)
X2
Also it is much cheaper to lose weight than add HP. Strip the car of everything that is not needed and put the driver on a diet over the winter.
Sep 21 2012, 08:41 PM
QUOTE(patrick3000 @ Sep 21 2012, 06:58 PM)
And without changing the cam, dual carbs won't get you anywhere near the +20HP you're looking for.
brant
Sep 22 2012, 09:47 AM
Is that the 75 exausy manifold?
New carbs and new exaust. Both will help a little now and a lot in the future
piss'n914
Feb 3 2014, 01:31 PM
Thats one thing that kinda sucks...is that it seems very hard to make big hp, with these engines. its not like hooking up a tuner, or CAI, catback or anything like that.
f1rocks
Feb 3 2014, 01:57 PM
Better tires and suspension
Mblizzard
Feb 3 2014, 03:35 PM
I have no track experience. I agree it is better and cheaper to lose weight than try to squeeze more HP out of the 1.7. I don't know if it is allowed and you have likely already done something but after removing the fuel tank recently from my car I was amazed at the weight of the thing. A smaller tank might be a way to lose weight? Just a thought.
