I am just completing an project to return my 914 (73 2.0) back to fuel injection and may be having an issue with temperaturre. I replaced the webers that were on it when I got it with a custom setup. The set up consists of:
the original intakes for the webers, a custom intake manifold that uses modern injectors ( ford f150 high impeadance) and a pontiac throttlebody frrom a 3.4 liter, a trigger wheel from Original customs, together with a megasquirt2. New stainless steel fuel lines from Tnagerine racing and new fuel pump. New VDO oil temp guage and it's related sensor.
Several people sent me MS tunes to get me started with the tuning process., which I apprecieted. I now have it running and it seems to be settup well for throttle response and getneral drivability. Howerver I am conserned about temperature. The oil temps seem to be in the 210 to 230 range and the CHT seem to be in the 325 or 340 range. THis may be a bit warm but is it safe to the heads? (with the webers and old oil t guage I think i was about 180-190 but that was an estimate since the guage was not marked well.
The last thing I did was to put back the suplemental heater fan, original host to the drivers side duct and a new hose from AA to the pasenger side duct. I toke a 25 mile test drive and towards the later part of the drive I smelt warm plastic smelll but assumed that was due to the tubes joining the ducts for the heat exchanges. However a few mile from home the oil temp started going up and reached 280 when I got home. I really don't know what the CHT was but can assume 380-390. I discovered that the new hose going to the pasenger side was sucked into the impeller and was turned into a rats nest of wire and plastic. I was able to get that out and am hoping most of the plastic is accounted for.
Today I took a 2 hr drive around town and the oil temp slowly worked up to 220 where it stayed for a while but got to about 240. The CHT where at 355-360. The drive was primarily 25-30 mph and in 3rd and 4th gear. I was not trying to keep the rpm high to push air.
questions:
1. is my megaquirt tune off and causing the temps
2. do I need to drop the engine and take off ducting and clean out the cooling air passages
Thanks
