Some details about the car:
- Delorto 36mm carbs (35mm venturis and appropriately jetted)
- Anacona Blue (original color) this is a fairly rare color, but very good looking.
- Runs well, I have re-jetted the carbs and they work well.
- No rust, paperwork indicated it was originally from California. It has a cat, so I believe to be true.
- Some interior wear, but all there.
- mileage indicates 141K, but probably another 5k on it. The odometer works intermittently when you are driving, although speedometer works. The mileage was supposed to be accurate when I bought it at 133k. It hasn't been driven that much since then.
- Many repair and parts receipts available.
I have had it for about 5 years, during that time, I have done several maintenance/repair items, such as: - All new brakes recently installed
- Two new tires/other two still OK
- New rear springs and shocks
- Replaced rear trailing arm bushing
- All new rubber for top and side windows - no leaks
- New vinyl covering for roll bar
- New fuel lines from tank to carbs
- Replaced many oil seals, have reduced the typical oil drips to a minimum.
- Replaced the battery tray and repainted it to match the car.
I will consider all reasonable offers, but this is a really solid car. Please reply to post or private message and I will send you contact information.
Thanks for looking, Bill
