TJB/914
Sep 16 2012, 05:14 PM
Hi Guys,
I recently purchased (5) Gas Burner 4-lug Mahle Wheels from Mark @ mepstein and had them Powder Coated with a Silver Metalic paint. They look real nice
BTY: Powder Coating cost $80.00 bucks per wheel.
My plan is to change them out for next years TC parade in MI. My Porsche Certificate says "Alloy Wheels" so why can't I subsitute Mahle for Fuchs & be factory original????? Polished Fuchs don't look factory??
Tom
Sep 16 2012, 05:53 PM
They look great. Can I have them back?
TheCabinetmaker
Sep 16 2012, 07:25 PM
Fuchs, Mahles, and Pedrinis are all factory alloy wheels.
Krieger
Sep 16 2012, 07:30 PM
Those look really good! I see you have the tow assembly. Can you tow that without removing the stock valence?
dlee6204
Sep 16 2012, 07:31 PM
Those look great!
914Sixer
Sep 16 2012, 07:58 PM
Mahles were factory alloys from 74-76.
Pat Garvey
Sep 16 2012, 08:01 PM
Nice!
Pricey, but nice!
TJB/914
Sep 16 2012, 08:15 PM
QUOTE(Krieger @ Sep 16 2012, 09:30 PM)
Krieger,
Yes, I can tow without removing the valence. The tow bar extends parallel about 12" then curves up to the trailer hitch without any issues. I also like the tow bar hookup tabs under the front bumper. Many times it saved me going up a steep driveway ramp from scraping the underside.
Tom
euro911
Sep 17 2012, 12:15 AM
The Fuchs look nice, but those Mahles look great (IMO).
What brand and model tow bar tabs and tow bar is that?
02loftsmoor
Sep 17 2012, 07:59 AM
the Brackets showing below the front valance, tie downs ???
914werke
Sep 17 2012, 08:18 AM
not to nitpick but if originality is the concern Mahle's were painted not powder coated.
Id expect the judges (?) would probably be able pick that up....
The do look very nice.
Cupomeat
Sep 17 2012, 09:04 AM
NICE!
I think that Mahle's are the best looking of all the 4 lug alloy wheels.
MUCH better than painted Fuchs and the holes in pedrinis make them look strange.
Nicely done (but I agree that Concours judges know and see ALL and are very likely to see they are powder coated and not painted. The substitution is fine, but the finish might lose you points.)
Jasfsmith
Sep 17 2012, 09:20 AM
QUOTE(TJB/914 @ Sep 16 2012, 07:14 PM)
Tom
You didn't mention what MY your 914 is. If memory serves me, the 4 bolt Mahle's were a '74 to '76 option. If your car is a '74, go for it. BTW, be prepared to be nicked for the incorrect tire profile.
Dave_Darling
Sep 17 2012, 09:24 AM
His user pic shows a chrome rear bumper with bumper tits on it. So it's a 74. The Mahles should be fine from an originality standpoint, at least.
--DD
euro911
Sep 17 2012, 10:19 AM
QUOTE(02loftsmoor @ Sep 17 2012, 06:59 AM)
Those are the tow bar brackets.
And a question - isn't powder coating considered a paint? ... just applied dry?
Do judges deduct points for powder coated engine tins? ... and suspension components?
Cupomeat
Sep 17 2012, 11:17 AM
QUOTE(Jasfsmith @ Sep 17 2012, 11:20 AM)
Tom
Good point, I looked at the bumperettes and assumed it WAS a 1974 car, but if it were earlier they might frown upon your choice and knock you down a few points.
TJB/914
Sep 17 2012, 02:04 PM
QUOTE(euro911 @ Sep 17 2012, 12:19 PM)
euro911
My tow bar bracket was custom made of heavy flar bar and attached with about (10) bolts. Overkill, but a good design by the PO in CA before it came to MI. Here is the only photo I have of the tow bracket.
BTW: I agree, powdercoating is paint with a different method of application.
Tom
Sep 17 2012, 06:17 PM
Paint is any liquid, liquefiable, or mastic composition which, after application to a substrate in a thin layer, is converted to a solid film. It is most commonly used to protect, color or provide texture to objects. wikipedia.org
Pat Garvey
Sep 17 2012, 06:43 PM
Bliz,
Can you describe the process used? These aren't flat pieces of metal. Kinda like to know - softening my opinion of this process.
Also, and I have no experience with Mahles, were the backsides finished the same as the front ....from the factory?
Pat
Dave_Darling
Sep 17 2012, 10:25 PM
QUOTE(mepstein @ Sep 17 2012, 05:17 PM)
True, but the judges won't give a crap about that. If the finish looks like the original finish, they'll be happy. If it looks different, you'll get dinged. The method used to achieve the finish is almost irrelevant.
--DD
TJB/914
Sep 18 2012, 07:35 AM
QUOTE(Pat Garvey @ Sep 17 2012, 08:43 PM)
Bliz,
Pat
QUOTE(Dave_Darling @ Sep 18 2012, 12:25 AM)
--DD
Pat, Dave & others.
I started with a really nice set of Mahle wheels so I inspected them carefully for a factory finish. It appeared to be some kind of anodized finished all over the entire wheel. I went to a local shop for a price to anodize them and they quoted a min of $150.00 per wheel. Too expensive, so I took them to Fred my high school buddy who owns a powdercoating business. Fred looked them over and said he can duplicate the factory finish with a Silver Metalic finish that looks factory for $80.00 bucks each. First they sand blast with a grab profile for the powder to stick too. Then it goes into the furnace to bake @ 400 degrees. My wheels have the same look/finish as on my business car 2012 FORD Fusion SEL. Next time you see one look at the wheel finish. Mine look the same & they look like the original factory finish/color in my opinion. I agree with Dave the judges will not ding you for this finish.
Tom
cary
Sep 18 2012, 02:36 PM
Just a note:
Seems $80 is the going rate to bead blast and powder coat wheels. That's what I pay here in Portland.
championgt1
Sep 18 2012, 09:55 PM
Those look amazing! I should do this to mine instead of spray paint.
Drums66
Sep 19 2012, 02:05 PM
Pat Garvey
Sep 19 2012, 06:31 PM
QUOTE(TJB/914 @ Sep 18 2012, 07:35 AM)
Bliz,
Pat
--DD
Pat, Dave & others.
Tom
Have to disagree. Though they're gorgeous, contemporary Parade judges will spot them immediately as non-anodized. But it doesn't matter - your 914 will attract much attention. Good luck. Pat
CMONNETT
Sep 19 2012, 07:40 PM
Not necessarily, there was a 914 entered in the concours at the 2004 parade in Ft Worth in the preservation class that had a full restoration and the judges didn't catch it. Until someone from the local region the car was from mentioned it.
kerensky
Sep 19 2012, 11:14 PM
QUOTE(Jasfsmith @ Sep 17 2012, 07:20 AM)
Mahle's were available in '73 as well. My '73 came with Mahles (It's a 1.7 with the full appearance group)
