Well, I got the car back on the road after a "minor" electrical fire.
Everything seems to be working, except that the low-beams cut out intermittently. Because they were going off at the same time, I originally suspected the headlight switch.
However, after tracing through PP's wiring, relay and switch diagrams--and noting that the fog lights remained on even when the low beams went--I'm now suspecting that the "short" fried the headlamp relay (I think it's referred to as "combination relay" [#27?] on the diagrams). Is that the one with PN that starts with 111?
Any advice/BTDT's would be appreciated.
Thanks in advance,
Steve A-
Oh BTW, the fire appeared to be caused by the front/ upper edge of the fuse panel/tray cutting through the insulation on one or more wires leading from/to the fuses. These wires looked like they had been resting on this relatively sharp edge since the car was built. I've since covered the tray edges with some plastic welting (like small weather-strip), so that should end it--but you may want to check on yours. I can take pics of my "fix" if anyone is interested.
Best,
Steve A-
