mr914
Sep 18 2012, 04:55 PM
Making progress on rust or ation on #269
Considering future proofing my project....
Currently the plan is to put the 2.2MFI back in the car, but was wondering
What size of fuel lines do i need for putting a 3.6/3.2 in sometime in the future?
Makes no sense of threading fuel lines twice...
Thanks
SLITS
Sep 18 2012, 05:01 PM
3/8" supply (8-9 mm)
5/16" return (7-8 mm)
Sep 18 2012, 05:04 PM
QUOTE(mr914 @ Sep 18 2012, 03:55 PM)
I using the stainless lines from CFR. Not sure about the size, but they seem to work just fine ...
drgchapman
Sep 18 2012, 05:16 PM
QUOTE(SirAndy @ Sep 18 2012, 04:04 PM)
My 3.2 uses CFR's stainless lines, which I think are stock diameter, no issues.
shoguneagle
Sep 19 2012, 12:44 AM
DITTO on the above. I use CFR stainless steel on my 3.2 Sixer
mittelmotor
Sep 19 2012, 12:53 AM
I'm using 8 & 9.5 mm lines for an LS1 V-8, and no issues.
RON S.
Sep 19 2012, 07:18 AM
I'm using -8 line from the tank bottom to the front mounted pump. From there it's 3/8'' stainless lines I formed for the supply back to the engine. Finally I
cut down to 5/16'' stainless line at the return.
5 years now, no problems.
pcar916
Sep 19 2012, 07:40 AM
I'm using -8AN for the supply line and -6AN for the return. -8AN was the closest to the stock supply ID.
Good luck
Eric_Shea
Sep 19 2012, 08:47 AM
8-9mm
mr914
Sep 20 2012, 04:43 PM
Not familiar with CFR lines. Will look them up
I had not planned on going with a braided line as I've got pans to install.
Figured I'd use double wall tubing 3/8-5/16 and either flared or compression fittings.
Thanks for all your imput
