QUOTE(AE354803 @ Sep 20 2012, 11:13 AM)
QUOTE(aircooledtechguy @ Sep 20 2012, 09:06 AM)
You will need to use your TDC mark on the fan and a timing light that is equipped with an advance feature in order to set your timing correctly. Most folks will tell you to set your MAXIMUM timing at around 28 degrees BTDC. So in order to do that, you will need to first set your timing light for 28 degrees of advance. What this will do is flash the strobe 28 degrees before the actual spark event so that when the distributor advances the timing you can actually use the TDC mark (which may be your only point of reference) set the timing at the notch in the fan shroud.
I thought there was a -27* BTDC timing mark on the fan, at least per the Pelican Parts technical article.
Some do; some don't. I've seen more 2.0L motors that have both the mark @ TDC and -27. Many have an "0" stamped @ TDC, some have just another red line @ TDC. I have seen some that are not marked at all @ TDC. . . VW didn't do us any favors when they marked these pulleys. . .
Just to clarify and add to what yeahmag said about the 28 BTDC rule. That is always just a starting point. EVERY motor is different, so every motor should be treated as an individual. I'm not sayin' we should give trophies to all motors just for participating,
but every motor reacts slightly differently due to tune, altitude, wear, exhaust, etc, etc. so when it comes to timing, the rules begin to blur a bit.
