Made some progress on the 2.4>3.2 upgrade this week. The PMS bolt in engine mount is fitted. Went with the bolt in version as the weld in one would have required an engineers report for rego. I was running the 2.4 with the PMS "Quick Six" bar but ditched it after it bottomed out on a ripple strip at the track.
Was a bit pissed off about having to modify the WEVO 915 tail housing for the reverse light switch. Apparently you can order it with or without the switch but I only found out after having purchased it without. Had to fix a minor oil leak around one the studs as well.
The 3.2 has been cleaned and checked over and is almost ready to go in. I'm using the old 1.5 inch exhaust system for the moment but will upgrade to larger primaries at a later date.
