All items include shipping. Please feel free to make an offer on a single item or multiple items. I prefer Paypal but a check or money order is fine too.
1] ::SALE PENDING:: 1973 Djet parts lot. Includes the following:
- 4 green top injectors,h
- ECU,
- wiring harness,
- Decel valve,
- anti flashback valve
- new FI seals (tip and flange),
- throttle position sensor,
- stacked vacuum elbow,
- driver's side and passenger's side fuel rails,
- three aux air valves (AARs),
- 5th cold start injector with plastic spacer,
- -017 cylinder head temperature sensor and resistor,
- -012 cylinder head temperature sensor,
- pile of vacuum hoses.
2] ::SOLD:: Tan seat out of a 73. Includes seat rails and adjuster. This seat is just about perfect -- vinyl is soft, no rips, cracks, or fading. Pretty remarkable.
3] ::2.0L Left and Right tin is Sold:: 2.0L plenum, 3 bolt intake runners, and airbox. Pieces are in good shape but need a cleaning. Price: $65 shipped.
4] ::Sold:: Fan hub, bolts, center bolt, thick washer, and 6 flywheel bolts with lock washers. I'm also including the pedal linkage rod I found lurking around. Items are cleaned, restored and ready to install.
5] Intake air temperature sensor. NOS Bosch part, 0 280 006 000. Price: $30 shipped.
6] ::Sold:: Set of 4 Fuel Injector elbows and 8 proper fuel injector hose clamps. Never used and ready to install.
7] Lot of relays. 3 round relays, 2 hi-beam relays, and one mystery relay -- I think this is the seat belt relay. Round relays all tested good, One of the high beam relays is tested good and the other is untested, mystery relay untested. Price: $50 shipped.
8] ::Sold::Factory Porsche Hood Crest. This sells for a mind blowing $200. This is probably for the 911 crowd but in case anyone here is looking for one, here you go.
9] Sideshift Shift Rod. Includes coupler at the firewall, the bushings are good. Price: $65 shipped.
10] ::Sold:: Side view mirror. Works on left or right. Chrome and glass are just about perfect.
11] ::Sold:: JWest fog light flasher relay kit. Never installed, as new.
12]Tail shift engine mount bar and engine mount bracket. Solid but could use a good scrub. Price: $50 shipped.
