Full Version: Starter removal
914fun
The top bolt on that holds the starter on has a casting bump on each side of the bolt head. I can hardly get a open end wrench on the top of the bolt and for sure cant turn it without hitting the casting bumps that are right against the bolt. No way will a socket go on ether. Do I grind the bumps off? Is there another special tool I need to buy?
dlee6204
It's suppose to be like that. Remove the bolt/nut from inside the engine compartment.
914fun
QUOTE(dlee6204 @ Sep 24 2012, 06:37 PM) *
It's suppose to be like that. Remove the bolt nut from inside the engine compartment.
Ok. I ran my hand to the back thinking that, but didnt see one. I guess cuz its inside the engine compartment. Thanks.
QUOTE(914fun @ Sep 24 2012, 04:48 PM) *
Remove the air cleaner for better access ...
Dave_Darling
Yup, I just did that... Transmission is coming out this week.
--DD
