Full Version: Heater Hole Grommet
pcar916
Does anyone know of a good grommet material or better yet, a nearly exact size grommet for these two heater hose holes in the front trunk. I just covered mine with tape because... well I just did. But I want to put a real rubber plug there and route a few wires through them as needed.
gothspeed
This is what you are looking for smile.gif ...... If these guys do not have the size you need, just google "closed rubber grommets" ......... you can then punch or cut the size hole you need for your wires through the webbing.
http://www.ebay.com/itm/2-x-Rubber-Grommet...m-/160519544814
These might work too:
http://www.anythingtruck.com/Merchant2/mer...amp;Screen=PROD
bulitt
Nice resource! Thanks for posting.
pcar916
I'll check these guys out thanks.
