hwgunner
Sep 27 2012, 03:19 PM
GPR has just made a special purchase of Sway-A-Way Torsion bars and we are passing the savings on to you. These are first come first serve and only while supplies last. These are for 914-4 front suspension only.
21mm Solid $199.00/set Regular price $253.00
22mm Solid $199.00/set Regular price $253.00
23mm Solid $199.00/set Regular price $253.00
20mm Tubular $244.00/set Regular price $305.00 Back in stock 5/23/2013
21mm Tubular $244.00/set Regular price $305.00
Plus shipping and Sales Tax in California and Texas. I have several of each so let me know what you want.
Jonathan
hwgunner
SGB
Oct 24 2012, 12:40 PM
Great timing. I am underway on bringing my car back better than ever. Can you advise which would be best for a street drive 73 2.0? I willl PM you tonight...
hwgunner
Oct 24 2012, 02:40 PM
that depends on what you do to the rear and what is "street" to you. A good solid set up would be 21mm front and a coil over set up for the rear with 150lb springs. if you want somethnig more stock i do have some 17mm available also.
jonathan
hwgunner
SGB
Oct 25 2012, 10:46 AM
Budget dictates 17 mm and no coil-overs at this time. Not prudent some would say. I will call you to order today or tomorrow.
Looks like an awesome deal. Thanks.
Nor.Cal.914
Oct 25 2012, 01:28 PM
Hey Jonathan,
I have a '75 with rear coilovers with 220lb springs and a chassis stiffening kit installed in the rear as well and was wondering what you might suggest for my setup? My 914 is basically my weekend driver now which mostly consists of Hwy 9/35/84 runs and hopefully some track days in the near future.
Also, what are the benefits of tubular bars vs. solid bars besides possibly less weight?
Please let me know! Thanks!
-Chris
Luke M
Oct 26 2012, 05:27 AM
Put me down for a set of solid 21 mm t-bars.
I'll contact you later today with payment info.
Thanks
Luke
hwgunner
Jan 11 2013, 03:49 PM
Still plenty left.
hwgunner
May 10 2013, 09:14 AM
tadink
May 10 2013, 04:36 PM
QUOTE(hwgunner @ May 10 2013, 08:14 AM)
what is the weight savings for the hollow bars?
thx
td
hwgunner
May 10 2013, 06:31 PM
depends on the size. what are you looking at??
jonathan
hwgunner
tadink
May 10 2013, 08:56 PM
QUOTE(hwgunner @ May 10 2013, 05:31 PM)
jonathan
hwgunner
20mm and 21mm - wondering what the weight savings might be....I'm going light and looking for any savings I can find!
thx
td
plas76targa
May 12 2013, 06:47 PM
Do you have any 21 mm solids left? PM sent.
hwgunner
May 13 2013, 11:15 AM
QUOTE(tadink @ May 10 2013, 07:56 PM)
jonathan
hwgunner
thx
td
I just looked and checked 21mm solids vs 21mm Hollow and the weight savings is roughly 1.8 pounds. I do not have any 20mm bars here to measure.
hwgunner
May 21 2013, 08:55 PM
75porsche914
Jun 2 2013, 03:44 AM
Very interested, what would be best for my 1975 914 2.0 street car?
The engine is now a 2.3/4
Thank you
hwgunner
Jun 5 2013, 03:58 PM
QUOTE(75porsche914 @ Jun 2 2013, 02:44 AM)
Thank you
That depends a little on what you have for rear suspension and if it is stock or not. If it is stock and you want a little stiffer front end then I would say you should stick to the 20mm bars, 21mm maybe but this will start to throw off the balance front to back. If you want bone stock then I do also have a set of 17mm fronts which is very very close to the stock bars.
jonathan
hwgunner
SLKWrx
Jun 6 2013, 12:02 PM
This looks like a great deal. If I'm reading the thread right, I'm upgrading to ground control koni coilovers with a TBD spring rate. Should I stick with 21mm? Car is 70/30 AutoX/Road. If so, let me know how to pay.
hwgunner
Jul 18 2013, 08:40 AM
QUOTE(SLKWrx @ Jun 6 2013, 11:02 AM)
21mm torsion bars are a good compromise for the street and AX. I might go a little stiffer but then I like a hard ride and am probably outside the norm. What ever you do you need to match those spring rates to the bars that you get. The balance is the most important thing. jonathan
