Full Version: Idiot move of the day! Need help
GulleyGulley
My beer muscles must have kicked into high gear or I had a really weak bolt. I snapped the bolt off on my lower pulley last nite. Anyone know what size bolt that is? Anything special about it or can I use one from NAPA
Cupomeat
Is your lower pulley the impeller pulley, or are you dealing with a six motor?
If it is the impeller pulley, do you mean one of the three bolts that mounts it to the hubm or the center bolt that mounts the hub to the crank?
to put it succinctly, What do you mean by lower pulley and which bolt?
JStroud
Not sure what you mean by lower pulley, maybe a picture would help.
Jeff
rick 918-S
bandjoey
A V8? Gee wish I had a V8! Normal pulley is the only 1 on a 4.
ottox914
Need...more... info.
GulleyGulley
Should have mentioned its an upright conversion Type IV (not in my 914). It's the center bolt that mounts to the crank.
SLITS
Center bolt is the bolt that holds the hub for the fan on.
M8 X 30 mm self locking
