QUOTE(Dave_Darling @ Oct 2 2012, 07:35 PM)
If there is a gasket between the CV and the output flange, you can put a flat-head screwdriver on the gasket and tap it with a hammer. You'll kill the gasket, but you should be replacing it anyway. You can pry the joint away from the flange, as long as you're careful not to scrape up the sealing surfaces.
--DD
Thanks Dave! Oddly enough I just got off the phone with a friend that told me the same thing about 911 cars. Tomorrow should do it!
